Event with Type Def Does not Work
I'm using an Indicator Type Def (normal) in my main Vi.
Value Change Event on this indicator is not fired/captured with the event struct.
Why ???????
When I disconnect it from the type def it works !!!!
The example illustrate this behavior (no event with type def linked when click on Change Cluster Value Button).
How to do ????
Eddy DUCHENE
12 F Chemin de Boutary
69300 CALUIRE ET CUIRE
educhene@laposte.net
(2,560 Views)
That's a bug in LV7 that the value signaling doesn't work for typedefs.
The workaround is to detach the control from the typedef.
LabVIEW, C'est LabVIEW
(2,557 Views)
