Event structure
I want to execute an VI when an changement occured on my global variable.
Any idea on how I can do that with a event structure or other way ?
Thanks.
Peter.
Labview 2010
(3,897 Views)
You can use the value signaling property of a control to fire the event programatically. So you can wire the Global to a control say a boolean to its value signaling property node. I am assuming your global variable as boolean else you need use a shift register to check with its previous value and fire the event.
(3,887 Views)
I'm not sure to understand, any example please ?
Peter.
Labview 2010
(3,881 Views)
Accepted by topic author Peter Saraiva
Hi Peter,
simply test for value changes and call your subVI when needed:
(3,876 Views)
Check the attached example replace the Gloabl variable control with the actual global variable.
This explains about the Event triggering through software. But Gerd's solution is the very simple one you can go for that.
(3,870 Views)
Thank you all for your help,
Gerd's solution is more simple. Smiley Happy
Peter.
Labview 2010
(3,861 Views)
Perhaps something like this.
(3,844 Views)
