Event structure in while loop issue
Hi FCance,
@FCance wrote:
this what i mean with "same control in 3 differents tabs"
But there is/was no tab container in your example VI…
Why do you need to duplicate those controls instead of using just one set of "Start time"/"Duration"?
@FCance wrote:
I tried your code it worked but it only cut data there is a point where i run out of data and the vi send error.
It is based on YOUR example with YOUR example data.
I also recognized the limited duration of YOUR example data: YOU need to implement some error handling!
Message 11 of 12
(865 Views)
Accepted by topic author FCance
Hi FCance,
Based on my understanding of your problem, I am attaching a VI to give you some ideas. You may want to modify this based on your needs as right now it is not really doing much with the event structure in the other case.
Message 12 of 12
(862 Views)
