Event structure for specific key combos
I am interested in placing a subVI in an event structure. The subVI will allow a user to change specific control setpoints for a seperate application I am running on a cRIO. I do not want to use a button, because these control setpoints should only be changed by specific people. I am interested in doing a CTRL+Button(a)+Button(b) that will register as a user event and execute the subVI. Is this possible.
I have a computer that communates with the cRIO and will be the computer monitoring for the event described. I have everything ready to go. As soon as the subVI is completed, the program will reconnect to the cRIO and load the new information. I really just dont want to use a button.... Smiley Sad
Windows 7, LV2011....if that matters.
(3,118 Views)
I'm confused. You said you don't want to use a button, but you want to do a CTRL+Button(a)+Button(b). ummm... could you clarify?
(3,109 Views)
I want a computer keyboard combo similar to ctrl +alt+del. Not a LV button that would be clicked on the FP. I want lv to register a keyboard combo similar to how windows would recognize the combo listed above.
(3,104 Views)
I think there is an easier way to do this. If someone has a better way I am sure they will reply.
But basically it boils down to keeping track of which keys are down.
LabVIEW 2012
(3,103 Views)
Thanks Steve! Your example got me going in the right direction.
I used CTRL+ALT+H as my combo. The attached code is how simple it can get. Not sure there is a better way than what I did Smiley Very Happy
(3,083 Views)
