Event handling is not working as expected (NI vision).
I am facing problem to handling Event structure.
I am trying to make one creating template vi, that can create templates from Images, from captring image from camera directly and as well from live streaming.
For that I have created Event structure with 3 different Event, but only captureing Image and create template from it, is working fine while other two is not even reponding.
Here in attachemtn I have attached My vi that I tried.
Please guide me where I am doing wrong.
Thank you very much in advance.
Ankit Ramani.
(3,888 Views)
-What is the Stop button mechanical action?
-Do you get any error?
-You don't stop the camera session or close the camera and there should be error and connected to outer loop.
-When you click stop does vi still executing or stopped?
-If you are not familiar with LabVIEW(which i am thinking) please look into below tutorials:
NI Learning Center
NI Getting Started
LabVEW Basics
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
LabVIEW Graphical Programming Course
Using the Context Help Window
LabVIEW Inbuilt Examples
uday
(3,859 Views)
Thank you for reply.
Mechanical action of stop button is Switch until release.
I am not getting any error.
Noramally only capturing image and making templates case is working fine, during this case stop button working fine, If I press stop button vi stop execution.
But in other two cases buttons are not responding at all, no ROI tool is working not save or stop buttons are working.
(3,850 Views)
-Why are you opening camera and configuring session inside loop?
-Why are you using 5 to event structure timeout?(Why are you polling?)
-What is inside Timeout event?(what is happening?)
-What is the Error Status in other cases?
-Please learn about using event structure and basics as i mentioned in my previous post.
uday
(3,842 Views)
Thanks for suggestions.
I will work on it 🙂
(3,840 Views)
When a front panel object event occurs that has been registered in an event structure event case, the front panel, by default, locks until the object's event case completes execution. Since the event has not finished executing it doesn't release the front panel to allow any buttons/controls to use.
While this solution may work, a better solution for programs with time intensive processes is to design your programing using a producer consumer architecture. See the link Application Design Patterns: Producer/Consumer below for more information on this topic.
Ref: http://digital.ni.com/public.nsf/allkb/D979D150E9FC253C86256BC7006F3E22
uday
(3,811 Views)
