Event handler eats up memory. Bad programing and/or bug.
Hello!
I ran your example on a Redhat Linux 8 machine and then on my Windows XP SP2 machine and the amount of memory reported by File>VI Properties>Memory Usage or alternatively Tools>Advanced>Profile VIs with 'Memory Usage' + 'Profile Memory Usage' enabled shows the similar memory usage on both systems when running the example for approximately the same amount of time and opening the subVI the same number of times. So I cannot see any indication of a memory leakage in LabVIEW.
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
Message 11 of 11
(342 Views)
