Event Structure is missing from the programming menu when the control correpsonding to a particular case is deleted.
After defining the different cases in an event structure corresponding for different controls (present in front panel).
when i deleted a control from the front panel for whom an event case has already been defined on the block diagram.
and then when i tried to delete the case corresponding to the deleted Control from the event structure,
the Event structure is not displaying any option for add/Delete cases,
 Moreover the option to add EVENT STRUCTURE from the programming menu is mising. How can i get the Event structure back in the programming menu ?
Kindly check the attached photos for better understanding of the problem
In one snapshot, i am unable to view the add/delete case option after right clicking on the event structure.
While in other snapshot, the Event Structure is missing from the programming menu.
i have repaired the LabVIEW too
but unable to recover it.
Seeking for Valuable suggestions
Thanks and Regards
Gaurav Pal
Message 1 of 10
(3,970 Views)
There is no need for you to repeate your self. Stick to one thread.
From your image I can see you are running in evaluation mode. Is the correct ?
What version of LabVIEW are you using ? Base/Full/Pro
Message 2 of 10
(3,959 Views)
Yes i am running LabVIEW in evaluation mode
but even in Working on LabVIEW evaluation mode, i was using event structure
and that was working fine
the version i am using is LabVIEW 2010 pro
Thanks and Regards
Gaurav Pal
Message 3 of 10
(3,955 Views)
You could try repairing your installation.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 4 of 10
(3,950 Views)
i have already repaired it twice
finally uninstalled the complete set up
and re installed again
yet event structure is not present in the programming menu
Thanks and Regards
Gaurav Pal
Message 5 of 10
(3,944 Views)
And you are sure it is the Pro version you are using ?
You can find that out from the vi in Help-> About LabVIEW.
Message 6 of 10
(3,938 Views)
Yes i have checked it
it is the pro version of LabVIEW 2010
and i had repaired it twice
then completely uninstall it and reinstall it
yet the menu is not showing event structure
can you suggest what should i do ?
Thanks and Regards
Gaurav Pal
Message 7 of 10
(3,909 Views)
Moreover i was using event structure in the past too
so it was present in the programming menu in the past
but now even after repairing and reinstalling , no event structure option is being displayed.
Thanks and Regards
Gaurav Pal
Message 8 of 10
(3,907 Views)
I have the exact same problem in 2010. Can't find it anywhere.  Help would be greatly appreciated.
Message 9 of 10
(3,865 Views)
You could try downloading the eval for 2011
Tim
GHSP
Message 10 of 10
(3,858 Views)
