Event History
Whit BridgeVIEW 2.1.1 when you call a vi whit a Event History whitout a new
alarme, just for look the history of alarm , nothing appear, nothing in the
history display. When a alarme appear , all the historic appear at the same
time.
My vi was built whit the HMI G Wizard ,is it a bug on 2.1.1 version or i
missing something?
(3,261 Views)
I could not reproduce what you decribe with BridgeVIEW 2.1.1, or I did not really understand what you mean.
When I run the analogtag.vi with a running BV Engine (alarmtest.scf) and change the slider value with enabled to have generated events, those changes/events show up in the alarmdisplay.vi, even without having an alarm (at level 80).
Attached are my test VIs/.scf.
Sorry, nobody else earlier took care of this "old" question. But I assume you updated your system anyhow to LabVIEW 7 and the latest LabVIEW 7 DSC Module
Hope this helps
Roland
(3,261 Views)
