Event Callback
Is it possible to trig an event when a VI is open. And then have a reference to this VI. I need to creat an application that will be scanning all the vi that are opened.
(3,068 Views)
Use Notifier Operations. Each VI could send a notifier while be opened. Send the VI reference as the data of the notifier. The main VI use "Wait On Notification" to get the VI reference.
(3,068 Views)
Nitrof,
You could use the All VIs In Memory application property and do a compare every few seconds to see if a New VI has been opened.
Do you need to know when a new VI is run in an application or when a new VI is created new and design is begun. If it is the first, use the first answer posted. If it is the second, use the method that I have suggested.
Randy Hoskin
http://www.ni.com/ask
(3,068 Views)
