Euclidean Distance?
I know that to measure distance between a set of points the equation is SQRT((x2-x1)^2+(y2-y1)^2)
I want to double the length of a line a-b for a new line a-c. How do I solve for c? Is there something in vi.lib?
LabVIEW 2012
Message 1 of 9
(6,417 Views)
This stuff was a looonnng time ago for me, but assuming a is common, wouldn't c just be 2b-a (calculated on a per x and y basis), without needing the squares and roots?
Michael
Message 2 of 9
(6,413 Views)
That might work but I think it falls apart with angled lines.
LabVIEW 2012
Message 3 of 9
(6,406 Views)
Easiset would be to use complex representation for the points:
Message 4 of 9
(6,389 Views)
So you have two points. A and B. They make a line segment AB and have length ||AB|| =  sqrt ( (b_x - a_x) ^ 2 + (b_y - a_y ) ^ 2 ).
You want to make a second point C such that ||AC|| = 2 ||AB||.
Then you say some nonesense about angled lines. Solving for C seems pretty easy to me.
Just compute C = 2 * ( B - A ) + A. Where B and A are points (i.e. clusters with an X numeric and Y numeric).distance.png
Also, there is a function in IMAQ called IMAQ Point Distances which find N - 1 distances between a list of length N points.
Message 5 of 9
(6,380 Views)
You did not really specify what datatype "points" are. (in my book I always use complex in 2D :))
The solution by majoris is basically the same as mine, except for the datatype. For the special case of "doubling", we can go even simpler. 😄
Message 6 of 9
(6,371 Views)
Accepted by topic author SteveChandler
Message 7 of 9
(6,366 Views)
Well maybe it is nonsense. Other than that thanks for your answer.
Who to give the accepted solution to? Darins was the smallest and simplest. In fact it is so simple that I regret asking Smiley Happy
LabVIEW 2012
Message 8 of 9
(6,347 Views)
Now why would you post something that proves my point?  🙂  (Sqrt of 200 is 14.142...)
Message 9 of 9
(6,321 Views)
