Ethercat com's between cRIO 9025's
I am setting up a control system in which I desire to communicate between two cRIO 9025 controllers via shared variables.  Can EtherCAT be used for this?  Would the controllers be directly connected (with cross-over cable?) or would there be a hub or switch involved?
Also, both controllers need to communicate with an HMI running Windows XP.  I was planning on using the Ethernet port's on the controllers for that.  How do you control what variables are seen on EtherCAT vs. Ethernet?
(3,073 Views)
Accepted by topic author TLE
EtherCAT is a specialized protocol for deterministic Ethernet communication. The 9025 controller may be configured as an EtherCAT Master; however, 2 EtherCAT Masters cannot be connected. The 9025 may be connect to the 9144 expansion chassis for EtherCAT communication.
With 2 controllers, you may use a router for network communications; such that, each controller may host network shared variables. Each controller will act as a separate system on the network, much like a PC network in an office.
 Hope this helps. Please post back any additional questions.
Cheers!
Patrick Corcoran
Application Engineering Specialist | Control
(3,049 Views)
Thank you, this answers my question.
(3,047 Views)
