EtherNet/IP Driver for Communication to Rexroth HydraulicDrive
I use LabVIEW and Rexroth HymulicDrive to communicate through Ethernet /IP. Now reading data is all right, writing data S-0-0860 and S-0-0800 is all right, but writing data P-0-4077 is wrong (EthernetIP CIP Set Attribute Single.vi;Details: CIP Error - Extended status may be available CIP Status: 0xe (Attribute not settable))
Rexroth HydraulicDrive Accessing command parameters
A command can be started by writing "3" to the operating datum. The command status is obtained by read-accessing the operating datum. On access to command parameters, the number of attributes results in a value of "7".
Thanks for any help!
(1,827 Views)
Hello
May I ask which version of driver you use?
Best Regards.
(1,415 Views)
