EtherCat Connection Issue
I run a test stand that uses a cRIO-9035 which is connected to an NI 9144 EtherCat. I recently added an additional NI-9214 to my system, but I have an encounter an error when I run my LabView project. The error states the cRIO is unable to resolve from the current dialogue, which I believe is caused by an error in the EtherCat Master, which gives the error “The EtherCat master adapter does not exist on the target controller” and gives three possible reasons as
“1: The NI-IndCom for EtherCat is not installed on the target.
2: No adaptor is configured for EtherCat.
3: Offline Adapter”
I have used NI MAX to confirm that the correct software is installed, and an adaptor is configured for the EtherCat, but when I checked for the offline adapter in the EtherCat, it was set to what I believe was previously a physical adapter, but read a message telling me the physical adapter does not exist.
In the Network Settings on NI MAX, one of my Ethernet Adapters which is in a TCP/IP Network mode is showing a line interrupt in the Packet Detection, though I do not know if this is the issue or how to fix it if it is.
On my physical EtherCat, I have a green light for Power and Run, though no light for the FPGA. I was not the one who built the system, so I do not know if that light should be on as well.
The LabView code previously ran fine, and no additional changes were made to the code, or to the physical system. Thanks and any help is appreciated!
(2,436 Views)
Here are some sEtherCat Master Properties.jpgLabView Conflict 1.jpgLabview Conflict 2.jpgNI MAX Network Settings.jpgcreenshots that might help as well.
(2,416 Views)
