EtherCAT Slave Error -2147138467 Danfoss drives
It should be a rare error, but I've received problems with 2 out of 3 different manufacturers of EtherCAT devices, making this seem common for NI & EtherCAT from my experience.  It seems especially wierd when the same devices work well on non-NI controllers.  I opened a ticket and will see where it takes me!
Message 11 of 29
(2,435 Views)
Hello
NI customer support modified the XML file for us and it worked. Sorry I am not sure what they modify. Give them a call they will help out.
Message 12 of 29
(2,416 Views)
The Following page has all the manuals for the FC 302 series.
http://www.ctiautomation.net/Danfoss-VLT-Automation-Drive.htm
Message 13 of 29
(2,388 Views)
Can you compare the modified xml with the original xml and post the difference. I have the same problem with AMC servo drives
Message 14 of 29
(2,157 Views)
Can you post your AMC servo drives' ESI file here? Maybe I can help you.
Message 15 of 29
(2,139 Views)
I'm having the same problem with a GE device, GE_EPXETC001.
Is there another solution other than modifying the XML file?
Message 16 of 29
(2,098 Views)
Can you please provide the ESI of the device as an attachement?
Message 17 of 29
(2,096 Views)
Sure, this is the file. I changed the extention to txt, because xml extention is blocked for upload
Message 18 of 29
(2,086 Views)
The ESI looks so far so good. I'm wondering what are the specific errors. Can you please capture a Wireshark log? You can follow instructions here.
Message 19 of 29
(2,074 Views)
I did, But I don't know how to read those.
please find them attached
Message 20 of 29
(2,048 Views)
