EtherCAT Initial Commands Configuration
Hi all,
I have a Labview2020 application, there is a cRIO9040 connected with Indra Drive Motor throught Ethercat. Inside the Labview Project there are a lot of parameters, specially Initial Commands.
I'm tryng to convert the application in Labview2023 version, at the first step (when I open the project using Labview 2023) Initial Commands are not more available.
I tried also to "Import Device Profile" with success but nothing changed.
Is there some workaround or way to Add again the initial commands? Or are missing some drivers to not see initial commands?
Opening the Labview Project with notepad ++ i can read still the initial commands but are not loaded correctly.
Attached:
Labview2020.bmp = Screenshot of opening Project with Labview2020 and Initial Commands available
Labview2023.png = Screenshot of opening Project with Labview2023 and Initial Commands not available
Project Notepad.png = Screenshot of Initial Commands still present inside the project but not correctly loaded with Labview2023
P.S. Labview 2020 and Labview 2023 are in different PCs
Message 1 of 10
(1,202 Views)
From your description, it looks like you have a working program, written using LabVIEW 2020 on Computer A connected to a set of hardware, call it Hardware A, that runs correctly.  You have a second Computer B with LabVIEW 2023 (and possibly a different set of device drivers and other utilities) that doesn't work (the "initial commands" are not available).
Who installed LabVIEW on the two machines?  Who developed the (original) Program A in LabVIEW 2020?  What changes were made to the program to run on Machine B?
From the very little information you provided to us, it appears that some "parameter files" that LabVIEW needs to read and recognize are not present (or, if present, are in the wrong place) on Machine B.  But that's just a guess.
Are there any LabVIEW experts that you can get to look at your two machines and their two LabVIEW installations and figure out what is missing or mis-configured?
Message 2 of 10
(1,172 Views)
Hi, Thank you for the fast reply.
I developed the working Labview2020 Source Code with a Development Laptop (Computer A) perfectly working with cRIO9040+Ethercat Device (Hardware B) . The Application still works on a Desktop PC with Runtime 2020 (Computer B) and cRIO9040 in version2020 (Hardware B).
Now i have a new Development Laptop (Computer C) with Labview2023 and i'm converting all my software for future development. Before connecting to Hardware B or update cRIO software to Labview2023 i would be sure to have a working software.
Basically the first action I made is to copy the Source Code from the old laptop (Computer A) and open it with the new one (Computer C), just opening the Labview Project in the Ethercat Slave there aren't "Initial Commands" parameters.
I attached Computer A and Computer C NI Max Software installed.It Should not be a Installation problem or missing parameters files because if I copy and paste and open the Labview2020 Source Code with a external development laptop with Labview2020 (Computer D) i can see still Initial Commands.
Computer A and C were prepared by IT department. Computer A is not more available cause leasing end.
Message 3 of 10
(1,157 Views)
Attached you can find the Project standalone, if you open with Labview2020 you should see as screenshot "External PC" attached (i tested on a Computer E with Labview2020).
If you open with Labview2023 Initial Commands will miss.
My question is (supposing it is a Labview2023 issue to open the Labview2020 project):
Is there some manual way to insert in the project or force the parameters manually?
thanks in advance.
Message 4 of 10
(1,151 Views)
Thank you for including the "View from NI-MAX" of the software installations on Computer A (LabVIEW 2020, which works) and Computer C (LabVIEW 2023, which doesn't work).  There are a number of (significant?) differences.
Computer C is missing:  Flex-RIO, IVI Compliance Package, Datalogging and Supervisory Control Runtime, NI-TClk, NI-TimeSync.  Of these, most seem to be hardware, and possibly are not needed, but I'm worried about the Datalogging and Supervisory Control module.  Hmm, I seem to have missed that only Computer A has NI R Series Multifunction RIO -- are you using such a device on Computer C?  [If so, you'll need to install the driver].  Similarly, are you using any Flex-RIO devices?  Computer C doesn't seem to have them.
Message 5 of 10
(1,105 Views)
Hi Emacrux,
In the LabVIEW EtherCAT properties dialog window, I think it's possible to just double-click on the row, and make your edits.  At least that's why NI says.  Here's the document: https://www.ni.com/docs/en-US/bundle/ecat-labview-api-ref/page/ethercatadvancedinitcmdpropertypage.h...
Also, to import EtherCAT XML files, here's a good write-up: https://lavag.org/topic/53602-ethercat-basic-project/
BR
John
Add motion to LabVIEW in 30min or less - TENET EMotion
Finding it hard to source legacy NI hardware? Try Extend Test
Message 6 of 10
(1,052 Views)
Thank you for the reply.
It is partially true, you can double click the row and edit "Data" Column only if there is the row, if the table is empty is not possible to insert a new complete row.
I tried  to follow the topic you followed but as the first attempt, i can upload with success the xml file but in labview2023 Initial Commands don't fill the table.
Meanwhile i'm trying to send this commands run time in my software, in the next week i will prepare the cRIO to test it:
Thanks.
Message 7 of 10
(1,032 Views)
I am having a very similar problem, did it work with sending them through the software?
Message 8 of 10
(788 Views)
Hi, yes it seems working, I need to check the complete application but test VI worked as intended.
I still think there is some incompatibility between Labview versions because I was forced to do some workaround before VI worked:
During first attempts to connect a new Labview 2023 cRIO with Ethercat Device (with the previously attached Project) and import Device profile, Some PDOs were added to the project. Checking the Name they seem duplicates of old PDOs. Now i have both in the project.
Now to let the VI working fine I must use "Receive PDOs (Controlword, Target Position etc..)" from the "NEW" PDOs list and "Transmit PDOs (R_statusword, R_ActualSpeed etc..)" from the "OLD" PDOs list.
In order to correctly write SDO you must create the connection and set device in "Configuration Mode", Write all the SDOs you need (Case 1..7).
After that you can set device in "Active Mode" and work normally.
Message 9 of 10
(706 Views)
Many thanks for your extensive reply!
I am trying to control a Beckhoff Slave that requires a InitCmd. I tried it in LV21, and when I saw your post that older LV20 was working, I tried it with LV18, but no success either. The case is now escalated with the support, lets see if something comes out of it. The problem is that I currently have no idea what all initcmds are needed, so it is also not possible to execute them manually. Furthermore, this is about one small servo motor in a new one off machine, so there should be alternatives to Beckhoff - still it would be great if it works, the more possible control, the better.
Many thanks again! Erik
Message 10 of 10
(683 Views)
