Errors with formula node
I have a formula node which gives me an error called.Error on line 1 is marked by a '#' character: "constant#=(Pi*f/c) Einsta=constant*sqrt("
I created a constant, but i gives me an error. wham I doing wrong?
Message 1 of 13
(7,284 Views)
It would be easier to help if you would attach a simplified version of the VI instead of a picture.
My first guess is that "pi" is a reserved word. (You don't need to define it and wire pi to the terminal.) Check the help. There might be other problems, but I don't typically debug images. Where do you define "constant"?
Message 2 of 13
(7,279 Views)
Accepted by topic author shivik89
The formulas are all the same except for the input value.  So why not bundle the inputs into an array (using Labview primitives of course), auto-index the array for each input and calculate the output.  Throw all of this into a subVI and get rid of that formula node.
aputman
Message 3 of 13
(7,254 Views)
Hi shivik,
one more question: why do you need a formula node here for those simple formulas? Use plain G…
Edit:
@aputman: What's the purpose of the FOR loop?
Message 4 of 13
(7,250 Views)
@GerdW wrote:
Edit:
Yeah you're right.  I forget that the primitives can operate on arrays.  Smiley Frustrated
aputman
Message 5 of 13
(7,244 Views)
As GerdW stated, no FOR loop required.
Message 6 of 13
(7,233 Views)
As others have said, try to use LV primitives, if possible.  The less typing a human has to do, the better.  😉
Bill
CLD
(Mid-Level minion.)
Message 7 of 13
(7,218 Views)
While I agree with everyone saying use the primitives over the formula node, the reason you are getting an error is because constant is undefined. Add constant as an output if you want it to work the way you have it set up
Message 8 of 13
(7,208 Views)
Or just declare it before that line.
float constant;
constant=pi*f/c;
Einsta=constant*sqrt(480*(Pinsta./G));
Eavg=constant*sqrt(480*(Pavg./G));
Epeak=constant*sqrt(480*(Ppeak./G));
Message 9 of 13
(7,202 Views)
And the root cause?  Typing.  I have to admit that I have this bias against typing because I so thoroughly SUCK at it.  😉
Bill
CLD
(Mid-Level minion.)
Message 10 of 13
(7,175 Views)
