Errormessage, please help explain
Hi all, I am working on a project which a DLL function is called. However, I encountered this error message which causes my vi to cease running.
If anyone of you had any experience with such error occurance, please kindly drop me a few line explaining any possible reasons which may cause such phenomenan.
Hope to hear from you soon.
Regards
ian.f
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,619 Views)
The most likely cause of that error is calling a function in a DLL with the incorrect number of parameters. Too many or too few parameters can mess things up quite well (trust me on this one - been there, done that). Usually, no damage is done. Check the function in your DLL and reproduce the parameter structure EXACTLY.
Rob
(2,619 Views)
Hi Rob,
Appreciate your input. Will double check on the parameters again.
Cheers!
ian
Ian F
依恩与LabVIEW
(2,619 Views)
