Errorcode 6 compiling
When I try to compile my Labview FPGA I get the error: Xflow - Program xst returned error code 6. Aborting flow execution...
I have checked all my inputs and they're all connected properly so that shouldn't be the problem. I never had any problems like this before while compiling.
It is a very simple program that's suppost to write a desired signal to the FPGA memory and read it again changing samplefrequency and amplitude.
I enclosed my file so you might find my mistake.
Thanks for helping
(3,090 Views)
The following KBs are related to this issue:
http://digital.ni.com/public.nsf/websearch/D0181D05C79F763D86256F8500732563?OpenDocument
You didn't include the subVI but maybe this is the problem:
http://digital.ni.com/public.nsf/websearch/FE379EAFF553982286256D740076B9C5?OpenDocument
I've noticed that there is one unconnected terminal.
Otherwise I cannot see any unbounded arrays or other problem causes.
Add more detail to your post the next time. Stuff like LabVIEW, FPGA, and RIO versions.
Regards.
Joris V
(3,068 Views)
