Error with Matlab integration
I am trying to use a simple matlab call in LabVIEW 2010 (SP1).  I get a "Fatal Internal Error: 'fpsane.cpp', line 442.  This happens consistently after doing 2 or 3 manipulations with the VI.
Here is a screenshot of the fail:
http://sharecapture.com/23efe988d67542aabf36cda3b77e2730
I'm also attaching the VI that fails.
Any suggestions would be greatly appreciated.
(3,012 Views)
Hi Jeremy,
Usually the "fpsane.cpp" error  means that an object in LabVIEW such as a wire or a loop tunnel does not pass an internal test known as a sanity check. If you take a look at this knowledge base on our website, maybe some of those fixes will help you. Let us know if that isn't working for you.
Travis Ann
Customer Education Product Marketing Manager
(2,993 Views)
Please do not post links to images that are hosted on a remote site. Why did you do it in the first place? You attached your VI, so you can attach the image just as well.
Does this happen on just this VI, or on all VIs? If it happens on just this VI, then you probably just have a corrupt VI. If it happens on all VIs, then you may have a corrupt installation of LabVIEW. In that case, I'd suggest doing a repair, or an uninstall/reinstall.
(2,984 Views)
