Error while trying Reading TDMS File
I recently performed data logging using DAQ 6009 and TDMS File. But I have run into another new problem.
The TDMS file I have created works with the TDMS file viewer perfectly. But there is no facility to copy the values in text format directly from the File Viewer.
I have approximately 1.5 million values logged into the tdms file and is impossible to record them manually.
Hence I tried reading the TDMS file, but I run into an error which says:
Error -2525 occurred at Read From Measurement File->tdms error.vi
Possible reason(s):
LabVIEW:  TDMS file data could not be converted into the specified data type.
I also tried it using "Open TDMS file" wired to "Read TDMS" but its giving an error.
I am geting confused as the tdms file runs perfectly on the file viewer.
My final aim is to:
1) Read the TDMS file using "Read from Measurement file".
2) Wire it to "Write to Measurement file" and convert it to .lvm file(text)
I hope this is possible. It is very important that I can copy/paste the values into the report. ANy other suggestions will be appreciated, since its my first time at LabVIEW.
Sorry if I have asked any rookie-type questions.
I have attached my VI as well as the tdms ( tdms and its index file) file.
Thank you very much.
(3,353 Views)
