Error while switching between VI's
Hi everyone,
In my application I have a main screen.
In this main screen, I can switch with some buttons, through different sub screens.
Yesterdag I was switching through my application and the following error came up:
"Error 1026 occurred at Call By Reference Node"
Can anyone tell me what the problem is or could be?
I looked on the internet but couldn't find anything.
Kenny
(3,632 Views)
The error message tells you exactly what is wrong: you are attempting to use an invalid vi reference. Why that is happening I can't say without seeing the code.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,629 Views)
Hi Kenny,
there's a reason why you cannot upload BMP pictures to the forum... PLEASE use real JPGs or PNGs instead!
(3,621 Views)
I am trying to use the k-nn classifier via machine learning toolkit in labview. I am enclosing a screenshot of the vi. I get the same error 1026, VI reference is invalid. I have no idea how to go about solving this. Any kind of guidance is most welcome.
Thank you,
Vysh
(3,435 Views)
Hello Vysh,
Can you share actual code (VIs, etc) that allows us to reproduce the issue?
Without this I cannot really find out what is causing the error.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,395 Views)
