Error while running exe (error 10)
Hi,i am not able to run and build exe and getting error like exe is not corporate whitelist and will not be allowed,but if i run it in other system its running  without any error,particularly in that system this error is coming,but one thing is before it was working fine in that same system, now i am getting that error.can any one help me to resolve this error.
Message 1 of 10
(4,518 Views)
What is the version number of your labview?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 10
(4,508 Views)
Hi geetha,
for "exe is not corporate whitelist" you should definitely ask your company's IT team...
For error 10: it seems there's a FileCopy or FileOpen operation in your program not able to succeed. You should do some basic debugging to find the place/function that throws that error...
Message 3 of 10
(4,507 Views)
LabVIEW 2012
Message 4 of 10
(4,505 Views)
Thank you GerdW,file opeation is not succed means  in  code your telling or problem is in PC,but file opening and closing opertaion i am doing correctly,could you explain me bit deeply.is it possible to block other exes in PC,but before this problem persist what are the exes i have builed for same code its working fine.
Message 5 of 10
(4,496 Views)
where is you file you are trying to access. check if it is in C then you may need permission
--Ranjeet
Message 6 of 10
(4,480 Views)
file its in D drive..
Message 7 of 10
(4,470 Views)
this is the error i am getting,see it in below attachment,please help me out to solve this..
Message 8 of 10
(4,421 Views)
Hello Geetha016,
This isn't a LabVIEW error- it appears to be due to your antivirus and/or a permissions error of some sort.  As mentioned by others previously, I would suggest contacting your IT department.
Tom L.
Message 9 of 10
(4,418 Views)
It looks like permission issue. Are you in admin mode or in user mode? It is blocking the application
--Ranjeet
Message 10 of 10
(4,416 Views)
