Error while loading Kinect demos
Hi.
When trying to activate a demo VI file using xbox kinect, MS-SDK and LabView 2011 we get the announcement the error message attached to this post. Does any one know why can it be and what should we do?
Thanks!
Tomer
(2,650 Views)
Tomer,
The exception the message is referring to should be displayed in that message if your error handling is correct. Is there any way you can post a screenshot of the block diagram so that I can see how you are handling your errors. Once this is corrected, you should see the exception and can then search MSDN for a solution.
-Nick-
Nick C | Software Project Manager - LabVIEW Real-Time | National Instruments
(2,627 Views)
