Error while building an application
HI Eddy,
this sounds pretty weird. If it is working on one PC it should be working on the other one as well. Are there any differences on the PC's? Operating system etc.?
Cheers, RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
Message 11 of 15
(673 Views)
As far as I know it's the same WinXP and the same LabVIEW installation.
The problem is that some weeks a go it was running on both PCs without any Error.
I decided to go on with the better (faster/more Memory...) one and til last week
every thing was OK.
I don't know when it happened because I don*t make a compile every day and it*s still running in the LabVIEW
development environment.
Eddy
Message 12 of 15
(671 Views)
Have you tried to repair or reinstall LabVIEW on that PC?
Ramona Lombardo
Message 13 of 15
(665 Views)
No. Not at the moment, because the other projects are still working fine.
Eddy
Message 14 of 15
(662 Views)
Good that in another PC it works, Some times these PC problems come to picture, check If you can build sample project and create exe and installer in the PC where you see the problem.  If that works there is nothing problem with labview. These reasons can be better explained by NI team.
Message 15 of 15
(657 Views)
