Error when user hits Cancel in File Dialog Box
@paulrobinson wrote:
is it possible that we can add to the exe file? bcoz after i make this a exe file this vi is not working
You replied to a 10 years old post 🙂 Besides, I have no idea what VI you talk about, and what you mean about "not working". Maybe if you attach your VI/project, and explain properly your problem, you get some help...
Message 11 of 14
(624 Views)
  Thanks for the reply and i have the vi with this this message when i add to the exe it is working but when i created as a installer it is not working.
regards,
Paul
Message 12 of 14
(620 Views)
Hi Paul,
what exactly is "not working"?
And why do you use such an old VI instead of functions from your current LabVIEW version (like WriteToTextfile followed by GeneralErrorHandler)?
Message 13 of 14
(614 Views)
regards,
Paul
I still do not understand what you mean about "add to the exe". You attached a subVI, which actually uses no longer supported VIs. So first of all, start to use proper File functions which already available in your LV2013 version. Second, you could explain what you try to do in your application. Ultimately, you could attach your whole project, zipped up, would be easier to see the problems...
Message 14 of 14
(612 Views)
