Error when trying to execute .exe after attaching an NI-DAQ Channel variable
In my development team, i bind my ni-daqx channel "FT001" to my variable "Variable1" (enable aliasing).
Later, after the build of the .exe aplication, i try to execute it on the target computer an i get an aliasing error with the variable.
In addition, I have exported the configuration of my NI-MAX from the development team to the target team.
Would anyone know how to solve this problem?.
Thanks.
(2,499 Views)
NI DAQmx Aliases don't fit into floating point numbers very well.
A string might work but, WHY not CREATE the Task, Channel, Scale, DAQmx things in the Project?
For about 3000 words....
A Very simple project
With a simple Main.vi
And if we open the PROJECT file in a text editor we see the DAQmx "Stuff"
Yup, All the DAQmx-yish things are right there in that *.lvproj file (you could even edit outside of the LabVIEW IDE-----Don't do that!)
So, what happens for "Deployment!"? oh....  This configuration file is written for you in the build output!
"Should be" isn't "Is" -Jay
(2,469 Views)
Thank you, but I dont want use NI-DAQ Task in my project.
I found a solution creating NI-DAQmx Global Virtual Channels and asociating them with my project.
Thank you very much anyway.
(2,449 Views)
