Error when placing DAQ Assistant..
When I place a DAQ Assistant to a Block diagram, an error as shown in the attachment(Japanese) displays.
For your reference, here is the English translation.
"--------------------------- [ Engine was not found. ] LabVIEW ---------------------------
LabVIEW run time LVBrokerAux71 is a version. 7.1 (or compatible version) LabVIEW run time Engine is required. For solving this problem, please contact the manufacturer of LVBrokerAux71.
---------------------------OK --------------------------- "
What I have to do to avoid this error and to use Data Acquisition easily?
NB: I am using Japanese version of LabVIEW
Thanks in Advance
Aneesh.
(3,160 Views)
Have you installed the DAQ driver. If not, then you can find it for your particular device at thissite. If you have installed DAQ, make sure it is the most up to date driver. This broker file is a part of the driver install, and it should be in this directory:
C:\Program Files\National Instruments\Shared\LabVIEW Broker
I hope this helps. Have a Great Day!
George
(3,147 Views)
Hi George,
Thanks for your advice. You are correct. It was a mistake of mine on the installation shield.
I reinstall the software and now everything is OK.
Thanks again
by
Aneesh
(3,143 Views)
