Error when opening Find Examples under the Help menu
Today when I tried opening the Find Examples under the Help menu in LabVIEW 6.1, it would not open correctly. The Find Examples window appears and then an error window appears on top of it with the following description -
"Error 1 occurred at open or create file (function 1)."
Then ther is a list of possible reasons.
I have had this version of LabVIEW installed for over 6 months and had no problems until today. I tried running the installation program for LabVIEW and repairing LabVIEW but had no success.
What should I do next? Is there a file/s I can delete and then install manually?
Rodney
(2,768 Views)
I've never actually heard of this error ocurring with the Examples Finder before. If it continues, I would probably just reinstall LabVIEW. That should clear up the problem.
J.R. Allen
(2,767 Views)
Thanks for your help. I thought that just by repairing LabVIEW the files would be fixed up but obviously not. I completely uninstalled LabVIEW and then installed it again and it now appears to be working correctly with no error. I just hope it doesn't come back again in the future.
(2,767 Views)
