취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
Error when building stand alone RT program for cRIO-9047
Im trying to build a stand alone program with application builder for my RT target on cRIO-9047. Im using LAbview 2022 32bit on Windows 11.
I keep getting this error:
Error 1 occurred at AB_RTEXE.lvclass:Create_INI_File.vi -> AB_Application.lvclass:Copy_Files.vi
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Command requires GPIB Controller to be Controller-In-Charge.
I have been using the same program för LV2019 with other hardware and it works.
I can also run my program in Labview 2022 without any problem. Its just when im trying to build my stand alone RT program i get this error.
0 포인트
1/3 메시지
484 조회수
You didn't give the full name of the LabVIEW Version you are using.  The Application Builder (according to NI) requires LV 2022 Q3 or newer (for both 32-bit and 64-bit versions).  This might be part of the problem ...
0 포인트
2/3 메시지
458 조회수
Thx for reply.
Im using LV professional with application builder included with version 2022 Q3 32 bit.Lv.png
I tryed to make a new project.
Not all code are included yet but it works now with this work around.
Perhaps the code missing that are casusing the problem, or a bug.
I have been reading about creating a new vi, putting the same code in to make it work.
But then i have to know what vi is the root cause of the problem..
Im still interested in why this happening and will get back in this thread when i know more.
All input are appreciated.
0 포인트
3/3 메시지
446 조회수
