Error when adding a Title to a Graph in Excel
I am trying to automate adding a graph to Excel.  The Easy Graph.vi is too simple for what I would like to do.
I recorded a macro of what I wanted to do, and then I copied it in LabVIEW basically.
My program is erroring out every time I try to modify anything on the chart (title, series values, series names, etc).
I cannot figure out why it will allow me to add a sheet, add the chart, rename the sheet, and then error out when I continue to use the Excel._Chart properties and methods.
I attached a sample file and my code.
Kenny
(3,277 Views)
Can you create the graph without error?
Tim
GHSP
(3,272 Views)
Here is an example of the chart wizzard that I help someone else with. It allows you to set up your graph titles and axis. I have never had to upgrade this feature from MS excel 2000 - 2007
http://forums.ni.com/t5/LabVIEW/labview-excel-2007-Axis-title/td-p/1226794
Tim
GHSP
(3,271 Views)
Ok, I figured out my issue.
It seems that you have to graph the data, before you can change any graph attributes, even though I have done that before.
Once I put the axis, title, etc after the graphing, then it worked.  Well, I also had specified my range wrong, so that errored out too.
Thank you for the help.
Also, how to you get a reference to the Chart Wizard through the excel activex?
Kenny
(3,251 Views)
I posted a snippet. You can take it from there. I do not remember how I got it before. I have not had to change it in six to seven years. I remember going through the MSDN and found the function. I think I made it from scratch to match the MSDN..
Tim
GHSP
(3,238 Views)
