Error when add seconds to Time Stamp format
I've created a subVI that transform an string data/time to Time stamp format.
The subVI seems that it works fine, but when I use the data 26/10/2014 and I add 1 day, it crashes! The result is 26/10/2014 23:00:00 instead of 27/10/2014 00:00:00.
Cordially
Vicen
(3,623 Views)
Hi vicens,
I don't think your VI crashes - it just outputs an unexpected result. Quite a difference…
What is the timestamp before you add 86400s to it?
Here's the result on my computer:
Looks ok to me…
Which timezone is your computer set to?
(3,615 Views)
Hi GerdW,
You are right. The VI outputs an unexpected result when... ONLY the timestamp is 26/10/2014 or concerns this timestamp .
My timezone is SPAIN.
Thank a lot.
Vicen
LV 2010/2011 on WinXP/Win7
(3,588 Views)
October 26th 2014 was the daylight saving time change in Spain.
Ben64
(3,580 Views)
Accepted by topic author vicens
Thank you both!
I think I've solved the problem.
Vicen
(3,527 Views)
