Error regarding
hai everybody
 the following occurred while trying to build packed libray,how to rectify this?
Error 1 occurred at AB_Destination.lvclass:Copy_File.vi -> AB_Source.lvclass:Copy_SourceItem.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_PackedLibrary.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller Possible reason(s): LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @. ========================= NI-488: Command requires GPIB Controller to be Controller-In-Charge.
(2,713 Views)
I am having this problem to.  I think it has to due with a file named copy_file.vi being made in a later version of labview than we are using for the rest of the programming
(2,644 Views)
