Error "Device identifier is invalid" USB-6501???
HI Smiley Happy
When i run the script "USB-6501 Interactive Control.llb", i have this error  "Device identifier is invalid"?
If you know another script that drives the "USB-6501" to check its lines,  please help me?
Best regards       Smiley Happy
Message 1 of 11
(4,965 Views)
This makes no sense..!! Share your code or screenshot..!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 11
(4,962 Views)
Its a NI code (attached file)
Message 3 of 11
(4,955 Views)
What do you mean by When i run the script "USB-6501 Interactive Control.llb"...???
--> Do you've USB 6501 listed in MAX, as shown in the picture below...???
USB 6501 available
--> Are you using correct string identifier as device name...???
Is device identifier correct
Message 4 of 11
(4,949 Views)
Message 5 of 11
(4,941 Views)
Ohh I see..!! Its debug time now...!!
Enable Automatic Error Handling:
Run the code, let the code come back with the exact location, where error is occurring..!!
Message 6 of 11
(4,936 Views)
I did Enable Automatic Error Handling
I have the same error!!!
Message 7 of 11
(4,930 Views)
Then probably you may need to manually dig down and probe, where exactly this error is occurring...!!
Mean while you can also run a Self Test on that device (from MAX).
Edited: Also try to write a small code (or use shipped example) to see if, you're able to use available channels (AI, AO, DI, DO) on this card.
You can probably use DAQ Assistant OR even test panels from MAX.
Message 8 of 11
(4,914 Views)
I use also this NI code "
I have no error, But it activates  all lines (8 lines/ port) simultaneously;  I want just to activate one line in the port.?
The script:
Message 9 of 11
(4,911 Views)
Accepted by topic author USRP
Right now I don't have time to look into the example code, that you provided...!!
But why don't you use DAQmx functions OR DAQ Assistant to write a code with whatever functionality you need...??
Message 10 of 11
(4,899 Views)
