Error "An exception occurred within the external code..." when stopping LabView
I am having an error "An exception occurred within the external code called by a Call Library Node...", see the attached image, when I am trying to stop LabView. As a result of the error, the tag engine doesn't close normally.
I am using LabView 7.1 with DSC. I read values from a LNS (LON) OPC-server.
Is this a known issue and is there any way to repair it? I haven't noticed any direct consequences because of the error except that when I re-start LabView and the close it again without having first rebooted the computer, tag engine sometimes starts again when it should stop. This is fixed by always rebooting the computer before restarting LabView. I am getting suspicious that there might be some strange behaviour because the error says "it might have corrupted LabView's memory".
For example, sometimes when I have made a copy of an input number field to another, they follow each other's value changes even though there is no connections between them.
Simo Martikainen
Message Edited by Simo Martikainen on 12-17-2008 03:11 AM
Message 1 of 1
(2,961 Views)
