Error on installation of NI-DAQmx 7.4: Unable to create temporary file
Hi @ all,
we have a problem during the installation of NI-DAQmx 7.4 on our Windows XP system, showing the following error message:
K:\NIInstallers\trunk\1.2.1\src\UberInstaller\UberInstaller.cpp(1118): IInstallerError 10009
Fatal Error. Unable to create temporary file.
Unable to copy original D:\suppfiles\niresdeu.dll to C:\DOCUME~1\de9adm01\LOCALS~1\Temp\nii53.tmp.
Windows Error Windows Error 999: Fehler beim Einlagern einer Speicherseite.
Exception code: E06D7363 ()
Fault address:  7C81EB33 0001:0001DB33 C:\WINNT\system32\kernel32.dll
Registers:
EAX:0013F69C
EBX:0000000C
ECX:00000000
EDX:0051FD54
ESI:0013F72C
EDI:0013F72C
CS:EIP:001B7C81EB33
SS:ESP:00230013F698 EBP:0013F6EC
DS:0023 ES:0023 FS:003B GS:0000
Flags:00000206
Stack Trace
Address  Frame    LogicalAddr    Module    SymbolName + Offset
7C81EB33 0013F6EC 0001:0001DB33 C:\WINNT\system32\kernel32.dll RaiseException + 82
004D1DAF 0013F72C 0001:000D0DAF D:\setup.exe
0046C6C3 0013F820 0001:0006B6C3 D:\setup.exe
0046CCDD 0013F848 0001:0006BCDD D:\setup.exe
0040DA58 0013FAC8 0001:0000CA58 D:\setup.exe
00410C43 0013FB78 0001:0000FC43 D:\setup.exe
00469DE4 0013FDA0 0001:00068DE4 D:\setup.exe
0046E30A 0013FDDC 0001:0006D30A D:\setup.exe
0046DC6E 0013FF10 0001:0006CC6E D:\setup.exe
004FAA2D 0013FFC0 0001:000F9A2D D:\setup.exe
7C816D4F 0013FFF0 0001:00015D4F C:\WINNT\system32\kernel32.dll RegisterWaitForInputIdle + 73
This error occured as we were trying to install NI-DAQmx 7.4 on a Windows 2000 system with LabVIEW 7.1. Because of the error, the computer and its operating system were installed completely new, this time Windows XP Service Pack 2. After a successful installation of LabVIEW 7.1 with the standard installation settings and NI-DAQ 7.2, we tried again to install NI-DAQmx 7.4. Then the above written error occured again. The computer is a Pentium III 1,2 GHz system.
Any help would be appreciated. Thank you!
Best regards from Germany,
Manuel
(4,211 Views)
There is a chance that you have received a bad driver CD. Please download NI-DAQmx 7.5 or 8.0 and run this installer. I would recommend using NI-DAQmx 8.0 but as it doesn't support some older devices anymore 7.5 might be a better option for you, depending which hardware you use. Please refer to the corresponding readme files.
Jochen Klier
National Instruments Germany
(4,194 Views)
Thanks, downloading NI-DAQmx 7.4 from the NI website fixed the problem!
Manuel
(4,177 Views)
