Error occurs when i try to install a built application containing Web services VIs
at the moment i am trying to create and install a built application containing a Web server and Web services VIs. I did the steps as described here: http://www.ni.com/white-paper/7747/en#toc13
But when I install my application on the target PC the following error occurs after the installation:
Error2: Failed to perform action
"[LV2011RTEDIR]LVWS\NILVWSPostInstallerScript.exe"
"[ProgramFilesFolder]DeployWebServices\Webservice.lvws"
What did I do wrong? The project example is attached
Development system: LV2011 SP1, WIn7
Target PC: Win7, no LabVIEW, but ALL possible additional installer/run-times installed
Elmar
Certified LabVIEW Architect
www.merecs.de
(4,735 Views)
I solved the Problem. Although ALL possible additional installer/run-times were installed, the NILVWSPostInstallerScript.exe was missing. There was a LV2010 and LV2012 folder with the NILVWSPostInstallerScript.exe, but no LV2011 folder oO. So I created a LV2011 folder with the .exe manually, started the setup again and everything worked fine.
www.merecs.de
(4,717 Views)
Hi Elmar,
I'm having the same problem (but with LabVIEW 2012).
Where exactly did you find NILVWSPostInstallerScript.exe and where did you copy it to?
Many thanks,
Sarah
(4,542 Views)
long time ago, but I can remember. You have to copy a folder.
e.g. I have the file in C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\2013\LVWS , but there is no LVWS folder in \Shared\LabVIEW Run-Time\2012
(I have a new computer, and for some reason I'm also missing the file in the LV2012 folder now.)
Try to copy from another version to 2012 U(or download my fzip). I also don't now, why it is missing. Maybe something during the LV2012 installion was wrong.
Hope I could help,
Elmar, CLD
www.merecs.de
(4,525 Views)
Thanks Elmar,
I moved the content of the .......\2013\LVWS to .......\2012\LVWS and all seems to be working now 🙂
Sarah
(4,508 Views)
