Error message in executable.After building.
I'm using an USB6008 device. I realized a working schematic using labview 7.1 but i've a problem.
When i try to compile executable file everithing is ok. But when I run the program it gives me an error:
VISA: ( HEX 0xBFFF000E ) The given session or object reference is invalid.
What can i do to avoid it??
(2,853 Views)
Hi, it seams that you run into a known problem.
It has been fixed in NI-DAQmx base 1.5 even if you can work it around following this KB steps.
[broken link removed; article no longer available]
Hope this helps.
Ciao. Nicola.
(2,826 Views)
