Error message (0x80000003) occurred in the application at location 0x07cc9240
Hi everyone,
I have a scada application with the following error message:
(0x80000003) occured in the application at location 0x07cc9240
Error is coming up in random, not at a specific moment.
I hope that someone had this error before and can tell me what is wrong.
Kenny
(4,713 Views)
Dear Kenny,
possibly this code is coming from an external application like an OPC server for example; within Labview it isn't defined. Best thing is to track down which VI is producing this error.
Martijn S
NI Netherlands
(4,688 Views)
Hi Martijn,
Is it also possible that a software package on the computer is causing the problems?
It is very difficult to track down which VI is causing the problem, the error occurs random.
And it is a runtime version, so jumping to the causing VI isn't possible.
Kenny
(4,686 Views)
Dear Kenny,
It is hard to say what the cause of the error is (since the code is external). The VI is communicating with an OPC server or other external software (ActiveX)?
You can also try remote debugging from your EXE.
Martijn S
NI Netherlands
(4,680 Views)
