Error loading vrml file
Yes it is, its just a test file.
And the VI doenst work here, the same problem as before.
Should I reinstall my Labview?
Message 11 of 23
(3,315 Views)
If no one else is using NI software on the computer, it's better to remove all NI software from the control panel (not only LabVIEW). Then you can re-install LabVIEW 8.5 either from
a disk or download it from the following link:
Let me know how it goes,
KostasB
Applications Engineering
Message 12 of 23
(3,311 Views)
I reinstalled labview 8.5, and the problem remains.
I cannot uninstall the program because we have a evaluation version of the DSC module, and if I unisntall we´ll lose it.
I still have labview 8.2 and 7.1 installed, should that be a problem?
Message 13 of 23
(3,308 Views)
No, it shouldn't be a problem. Does the same error occur if you create the same VI with LabVIEW 8.2 instead of LabVIEW 8.5?
Message 14 of 23
(3,287 Views)
No,
But nothing shows in the 3d picture control, but no error happens
Message 15 of 23
(3,248 Views)
Still not working, any other suggestion?
Message 16 of 23
(3,040 Views)
Does anyone have a known good VRML file I can try to load.  I can't seem to find a good example.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 17 of 23
(3,038 Views)
I've already sent a VRML in this post, and I've already tried other vrml's I've found in the internet, and yet again it doesn't seem to work here.
Kostas B already tested my VRML and it worked, with my own VI, Felipe from the NI technical suport too. I've already reinstalled the software many times and tried on different versions of Labview and the error remains.
Do I need a toolkit or something extra for it?  Is Windows XP service pack 2 not compatible ( o.O ) ?
Message 18 of 23
(2,658 Views)
Hi Yves Bau.
Did you find a solution to this problem? I get the same error.
Message 19 of 23
(1,978 Views)
I too =( WinXP SP2, LV8.5
Message Edited by DFooz on 06-13-2008 08:16 AM
Message 20 of 23
(1,925 Views)
