‎09-18-2014 11:20 PM
I found this page: https://decibel.ni.com/content/docs/DOC-33812, and wanted to view the code that was being used.
I opened the main vi, I got the following message: "Error loading niimaqdx.dll". I am using windows 7 X64, and I'm guessing this project was done in a 32 bit windows. Is there a way I can solve this problem?
Thanks!
‎09-19-2014 05:39 AM
Do you have the ImaqDx drivers installed?
Look in MAX under 'software' for something like this:
‎09-19-2014 03:34 PM
Hello Nando88,
As Sam_Sharp said, it is important to verify if is installed the IMAQmx Driver on your development system. Also it is important to check if your version of IMAQdx is supported by Windows 7 64 bits. I recommend you to take a look the following link with the information related with the compatibility of IMAQdx and different operating systems.
What Version of NI-IMAQ does my operating system support?
If we have everything in order, the most possible cause for this error is a corruption in the registers of Windows 7. In this case we would have to uninstall the Vision Acquisition Software (NI IMAQ, NI IMAQdx) and re-install it. But first, I would like to know which version of LabVIEW do you have?... Depending on the version, I will share with you the most recent Vision Acquisition Software compatible with your version hoping that this upgrade solves the problem.
I will keep an eye on this forum.
Regards!
‎07-05-2017 12:33 PM
Hi Nando88, hi AntonioSM,
i get the niimaqdx.dll while the installation of VAS_2014_02.
With best regards,
Checkmate
‎07-06-2017 09:26 AM
Hi Checkmate this is a very old forum, to get better answers I recommend you to create a new one.
LaNiña | CLAD
