Error in using the tds2xx Example2.vi
When I run it, it comes an error "Property Node in TKTDS2XX Write.vi->TKTDS2XX Set-Query SESER.vi->TKTDS2XX Set Conditions for SRQ.vi->TKTDS2XX Example2.vi" which I don't understand, since I am just a beginner. Anyone can tell me what the error is and how to fix it.
I cannot post the example2.vi to this web, if anyone want the example2.vi, sending me email ee_cwkac@stu.ust.hk
Thank you very much
(2,503 Views)
In this case, the important part of the error is not the text, but the error code number. What is that value? It will give a better idea of what the problem is...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,503 Views)
