Error in Get Next Non-Text Sibling for XML without CR at end of tag
Hallo all,
I'm having a strange error parsing XML files with labview. I have an XML file in one single line, without CR at end of each tag. A normal browser or XML parsing tool is capable to read it, but not with Labview.
The error I have is with "Get Next Non-Text Sibling.vi", which internally fails to read Type property (Error -2630, Property Node (arg 1) in NI_XML.lvlib:Get Next Non-Text Sibling.vi->XML Get Siblings Childs Nodes.vi->Encode data to label (Path).vi).
Labview XML parser works if I add a CR at each tag/node.
I'm quite sure this is a labview bug. A workaround I have found is to open the file, then save the file with Save File (Pretty Print) method and reopen it again, but it is time-consuming and I would like to avoid it.
Daniele
(4,104 Views)
The error indicates that no sibling exists, but without looking at your code it's difficult to figure out the problem.
Can you post your VI?
(4,077 Views)
Here part of my parser, please note that the same XML with CR between ">" and "<" works like a charm.
Daniele
(4,063 Views)
Which node do you pass to XML Get Siblings Child Nodes.vi ? That is also important.
I can imagine the following scenario causing your problem: Your input node has a child node C,, but this child node has no siblings. Get Next Non-Text Sibling.vi will fail in this case. If you put a <CR> at the right position in your XML you create a text node with content <CR>. If this text node is a sibling of child C then Get Next Non-Text Sibling.vi still won't return anything but no error should occur. IMHO this is expected behavior. You can however implement your own version of Get Next Non-Text Sibling.vi. Use the Next Sibling property and check if it returns a valid refnum.
(4,054 Views)
Accepted by topic author dirida
You were right, I did my own Get Next Sibling taking care of text nodes (which includes also CR, I did not know it!).
Now it is working, there is no labview bug, also if XML functions documentation is very poor.
Thank you,
Daniele
(4,044 Views)
Great to hear that it works! Regarding XML you should also consult non-LV-specific documentation. The tutorials at w3schools are great resources. Here is the DOM tutorial: http://www.w3schools.com/dom/default.asp .
Also note that the LVXML parser uses Xerces internally so if you encounter something really weird it can sometimes help to look at the Xerces documentation.
candidus
(4,037 Views)
