Error due to NI_Report class building executable
Hi Jose,
If you are still having an issue with Error 7, I found a similar forum post regarding the same issue.
It could be an issue with your file paths. Also, if you are using LabVIEW inside of a virtual machine, there may be memory allocation settings you can change to resolve the "not enough memory to complete operation" warning. Running multiple applications on the host and using a virtual machine can take up large amounts of memory.
Let me know if this information helps to resolve your error and warning.
Warm Regards,
Tanner
Tannerite
Message 11 of 12
(553 Views)
Yeah,
I found a solution in this thread: https://forums.ni.com/t5/LabVIEW/Error-7-occurred-at-Open-File-vi-Open-File-NI-488-Nonexistent/td-p/...
I just needed to be more careful where the supporting files where located. Now the program is working well.
Jose
Message 12 of 12
(540 Views)
