Error code 6: Generic I/O error with cRIO TDMS
I am trying to use the TDMS VIs in LabVIEW 8.6, but the open TDMS VI is giving me error code 6, the "Generic I/O error".  The file path is specified like this: "c:\data\lotsofdata.tdms".  Anyone out there have an idea of what I could do to get this working?  Please let me know if I can provide more info about the error!
Thank you,
Alex
(4,199 Views)
Please change your path from ""c:\data\lotsofdata.tdms" to ""C:\data\lotsofdata.tdms", to make the "c" upper case.
That's a known bug and will be fixed in the next version.
(4,186 Views)
Thanks, I'll try that tomorrow.  I saw this post:
http://forums.ni.com/ni/board/message?board.id=280&message.id=5722&requireLogin=False
Which said to use a lowercase "c", and my c was already lowercase.
Thank you!
(4,175 Views)
It should be upper case, you can try it tomorrow 🙂 and post here if there's still any problem.
(4,172 Views)
Changing the C to uppercase didn't work. 😞
However, I switched over to the G TDMS library and it's working fine.
Thank you for the help!
(4,151 Views)
Oh sorry, I made a mistake, it should be lower case, only lower case "c" could work in LabVIEW 8.6 on VxWorks. Then your problem of error 6 is not related to the upper/lower case problem. Would you please tell me whether you have such a directory there? Or would you like to post some screenshot of your block diagram of your VI? I'm not sure what other reasons could cause error 6. Thank you.
(4,123 Views)
