Error code 42 from Call Library Node
I get this error code when calling into a DLL via the Call Library Function node.
The description isn't very helpful.
Any idea what it means?
Thanks...
-Umar.
(4,225 Views)
Since the description for that error is "Generic Error", it could mean anything, and it depends on what your code was trying to do. Which was what, exactly?
(4,223 Views)
I was calling a function in a dll.  The calling convention was C.  There were no parameters, and a unsigned 32 bit return value.
The Call Library Function successfully found the functions exported from the DLL since they were present in the pull
down menu in the configuration window.  I am passing the path to the dll via a terminal on the Call Library Function node.
I think that is all relevant info.
Anything I'm missing?
Thanks...
-Umar.
(4,218 Views)
Well, that more information, but not quite enough to pinpoint the problem. Smiley Wink What does the function do? Can anyone run this DLL, or is it hardware-specific? If anyone can run it, can you upload the code? Have you verified the function works by calling the DLL from another programming environment, like C? Does it work if you don't specify the path to the DLL on the block diagram?
(4,211 Views)
Ah...
It is HW specific, so you won't be able to run it.
I got this DLL from someone else and I don't have the source code, but
I know he has tested it and it does work.
I'll try it without passing in the dll path, and I'll get answers for your other questions.
Thanks...
(4,185 Views)
Other possibilities: Does the DLL depend on other DLLs? Are those private DLLs? If so, are they in the same directory so they can be found, or are they in the Windows\system32 folder?
As you can see, there are many possibilities...
(4,183 Views)
