Error code -301709 while using NI USB 8451
hi,
          I got the ERROR code (d) -301709 while i was working with NI-USB 8451 hardware.I would really appreciate your help in figuring out ,what causes this problem?
  It was working fine till the yesterday  and all of a suden it started giving me the error (d) - 301709.
(3,248 Views)
Hey hardik,
This sounds like a hardware problem.  I have heard of this error when the external connections of the device are not connected tightly.  I would check all of your connections and see if the error shows up again.
I have also seen this error occur when the grounds of the devices (the 8451 and the UUT) aren't connected together properly, so it is possible this could be your issue.
I hope this helps!
Jason W
(3,226 Views)
