Error code 2147138480 in Setting Scan Engine Mode to Active mode
Hello everyone.
There is a problem with the SDI Plug-in Parker E-Series example.vi
The main part of this problem is converting the scan engine mode from configuration mode to active mode.
The error code is: 2147138480
The devices I use are cRIO-9040(Industrial computer) and eCLD-4DCPC173A(stepping motor driver)
Thank you for your help.
Duke
(1,287 Views)
Dear AaBb01010209 ,
This error occurs when the slave device cannot be found. Please check out this forum post as well https://forums.ni.com/t5/LabVIEW/Error-2147138480-in-Set-Scan-Engine-Mode-to-Actif/td-p/2238152.
Best,
Anasei.
(1,159 Views)
