Error and weird behaviour in executable launch
Hello guys,
So, finally got the app working again. The issue was with a few paths, which weren't transferring into the executable. so fixed 'em.
I am still working on the accessibility of the block diagram on the app. But as my application doesn't really need the debug window on my executable, i chose lesser or the two evils, for now.
I don't really want to do a remote debug session but if that's the only way to go, i will do that.
But thanks for the invaluable input guys. I'll still keep this thread active for any new ideas to pour in Smiley Happy
RP
Message 11 of 13
(414 Views)
Yes, that is the only way to go. The only way to access the block diagram of an executable (with debugging enabled) is through a remote debug session. The "Enable Debugging" switch allows you to do remote debugging; it never allows "in-application" debugging. You can debug an executable running on the same computer as the LabVIEW development environment but it's still a remote debugging session - you must use the development environment to do it. Did you try remote debugging, or were you hoping to do something else entirely?
Message 12 of 13
(412 Views)
Hey Nathan,
You are on the money, I was trying to accomplish just that but did not know that there's no other way to do it. Thanks.
I'll give remote deguggin a try and hopefully it'll work.
Thanks again,
RP
Message 13 of 13
(410 Views)
