Error Vision Acquistion
Vision111111.PNGChào mọi người !
Tôi muốn hỏi:
Tôi đã cài đặt nó một cách chính xác nhưng tại sao không có thư viện Vision Acquistion?
Cảm ơn bạn !
(3,745 Views)
Accepted by topic author lehuynam
could you please describe your problem in English?
(you could for example use a translation page for this)
Thanks.
Greetings and Regards,
James
(3,705 Views)
During the Drivers installation you need to select IMAQdx and/or IMAQ for NI Vision Acquisition.
-You can also check in NI MAX or license Manager what are the modules installed.
uday
(3,681 Views)
Hi lehunyam,
Install Vision acquisition software once again. While installing, choose all drivers of Vision acquisition. It will solve the problem.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(3,679 Views)
Thank you ! I installed success
(3,658 Views)
