Error Using Array of Clusters on XY Graph
I'm somewhat new to LabVIEW.  I'm trying to create an XY Graph of readings from 4 sensors (Y1-Y4 data) vs time (X data).  I thought I had followed the example from NI website but I'm getting this strange error.
These cannot be wired together because their data types (numeric, string, array, cluster, etc.) do not match. Show the Context Help window to see what data type is required.
The type of the source is 1D array of
cluster of 2 elements.
The type of the sink is 1D array of
Any help will be greatly appreciated.  See attached VI
Message 1 of 9
(2,716 Views)
Hi
I wasn't able to open the file. Please save it for LV 2020.
For plotting an XY series of data, you need 2 arrays of doubles, one for X points and the second for Y points.
They should be then "bundled" as a cluster of 2 arrays to be ploted on XY plot
If you want to plot 4 sets of  XY values, you need to
create 4 separated bundles of Clusters, then build  an array of these clusters.
Message 2 of 9
(2,696 Views)
Thank you for the reply.  I saved it as 20.0.  See if you can open this one.
Message 3 of 9
(2,675 Views)
Accepted by topic author gemoco
You are mixing 1D and 2D arrays.
I cannot see how your IO is configured, but are you really reading N channels one sample each? Shouldn't that be only 1 channel, 1 sample? In that case you'll get 1D arrays and things will work.
If you really have N channels each (and N is different for each IO, you need to wrap all bundle as follows to get an array of xy.
If N is the same for all, this will also work:
Most of your shift registers are not initialized, meaning they will retain data between runs and grow forever. So fix that too!
I don't have any DAQ installed, so I cannot comment on your hardware configuration. Do you really have four different devices?
Message 4 of 9
(2,671 Views)
Thank you for saving for 2020.
In your code, you need to initialize the array like you did with the X array.
Then Concatenate the inputs of the build array so that you will have a 1D array for Y values. Then you can bundle 2 x 1D arrays to plot XY.
Ensure that you are getting same number of points from daq (Y) as the time (X). At every iteration you get 1 scalar for X (time): You will get then 1 scalar per reading from the Daq. If you are getting just 1 scalar, from daq, then you need to use Index array to get the first number of the array.
I did the modifications in your code for 1 channel so you can see how the wires should go together. Do the same for the other 3 channels and you will be able to plot your data.
Be mindful that this solution consumes memory - build array creates a copy of the array in memory.
Message 5 of 9
(2,666 Views)
If you concatenate the channel arrays, they will be N times longer than the time array, so this will not work right.
You could make your life significantly simpler by not allowing dt changes during the run. Now all you need is a plain waveform graph (or maybe even a chart).
Message 6 of 9
(2,660 Views)
Thank you both @LVNinja and @altenbach for your replies.  Good information on both accounts and as usual there is more than one way to accomplish anything in programming.
@altenbach
Putting the reads back to 1 channel, 1 sample solved the error I was getting.  I had experimented with reading multiple channels on a single read in a previous version of the app and forgot to change back to 1 channel before I copied and pasted to add new inputs.  That error message was confusing to me and not very indicative as to the actual problem.  Probably just because of my lack of experience with LV.
My hardware for this app is a CompactDAQ cDAQ-9189 with modules for Thermocouples, RTDs, and AI 0-10V modules for differential pressure sensors, humidity sensors, and possibly other sensor types.  That is why I have different tasks for the different sensor types. I have created a Simulated cDAQ chassis because I don't currently have the actual hardware available.  The actual number and types of sensors has not been defined at this point in the project.
I actually did have all of my shift registers initialized in an earlier iteration of the app.  I will get that fixed.
The goal of this app is to run for some period of time (probably several minutes) capturing each sensor value (Ys) on every time interval (X), probably 1-60 seconds.  Then when the app terminates, generate a report (probably in MS Word or Excel) with a graph of the data included in the report.  So, for a LV newbie, I've got some learning to do.  LOL
My intent is not to change the dt during the run but to set the interval before the app is executed.  I guess I should disable that "Seconds per Data Point" control at runtime, huh?  I didn't even notice that.  🙄
Again, thank you both for your replies and for sharing your knowledge with struggling LV developers like myself!
Message 7 of 9
(2,625 Views)
If dt is constant, I definitely would recommend to use a waveform graph. You can set dt for the x-axis before the loop based on the loop time using a property node. Now you only need one shift register containing a 2D array of all data where you append one row of data with each iteration. Many fewer cats to herd. 😄
Message 8 of 9
(2,611 Views)
Thanks!  I'll have to see if I can figure out how to do that.  I like fewer cats! 😁
Message 9 of 9
(2,592 Views)
